Results inaccuracy
I often see that Zwiftpower results after a race are inaccurate. Riders who finish far behind me are listed ahead. How can I trust Zwiftpower in other instances?
Is it possibly a points races. in which case scoring is done based of some primes and finish positions which will differ from the results you see in companion. Zwift directly does not support points races but zwiftpower does.
If not that then would be good to see some example races if you have link to the zp result?
Are you referring to your last activity, some 30-40 minutes ago ? If so that was a group ride and ZwiftPower results for that activity are random.
Possibly. My observations have been more random so I might make more systematic observations in the future to check. Thanks.
Mark Andrews
When an event is based on time rather than distance, you should ignore the ZwiftPower results. If it’s based on distance it should be correct whether it’s a race or a group ride, unless it’s an event designed around segment points or bonus seconds.
Succinct and clear. Thank you.
Mark Andrews
