Resistance problem with bkool and zwift. I can’t pedal at over 20 watts, same problem with computer and phone app. Any help?
What bkool trainer do you use. How do you pare it to your computer Ant+ or Bluetooth?
Bkool smart pro 2 with ant+ connection
Did you do a trainer calibration?
You should pair it as power source as well as controlable, using the option that has FE-c
Hi Jari
I have the same problem, my FTP is 230, but at a Bkool Go trainer I can’t pedal over 80 watts, Did you find a solution ? Thank you
Hey Octavio!
There was a mechanical fault in my trainer. It was first tried to fix it remotely, but it didn’t work. My trainer went to Spain for repair, now everything is ok
Thank you
But I think I have a different issue, because my Bkool works fine with the Bkool App, only at Zwift have problemas
