Remove Kickr
Hello all. Hoping this is a simple question! I have a Kickr and my wife has a Kickr Core in close proximity in our basement! When I open Zwift it wants to connect to the Core and has delayed my Kickr showing up! Sometimes I have to back out and start over! Is there a way to remove the Core from my Zwift?
Are you on a PC? If so delete the prefs.xml or something like that and then start up zwift, pair your trainer and it should remember it.
I’m using an IPAD to run Zwift? Appreciate the insight, would the IPAD be different?
Yes, not sure if you can do this with an ipad?
The file is knowndevices.xml and you can’t remove it on an iPad but that data will be reset if you delete and reinstall Zwift
