I might be missing something but I followed the instruction to remove followers by following them first then you can remove the follower using Zwift Companion. However, the option “REMOVE FOLLOWER” is still not an option even if I follow them. I am only seeing “UNFOLLOW” and “CANCEL” buttons. Am I missing something? Please help.
On android, in the upper right hand corner of the rider’s profile above the follow/unfollow rider button are 3 little dots. Tap those dots and a “remove follower” dialog will open.
Edit to add: I just discovered this unannounced feature… You no longer need to follow them before you can stop them following you.
