Real time avg. watts?
Is there a way to display the real time running average watts for a ride?
Bill Black
Not within Zwift itself. Dependant on the trainer you could send the readings from the trainer to an external device such as a Garmin Edge.
Click the blue menu button during a ride. Keep riding as this does not pause the ride. Your average power will be shown on a graph on the first screen presented to you.
Click ‘back’ to return to your ride.
Would be interested to understand what you intend to do with this information?
For every QS (quality session) I do, I have target average watts for intervals as well as recovery periods and having a real time running average displayed is helpful although I likely will use my Garmin so that I can mark the ints and have displayed avg. numbers for those as well.
Isn’t it easier to just make a workout?
Yes, but using erg caps your effort and making progress means exceeding the scheduled spec.
As with a lot of things with zwift, it is something a lot of people want, there is a work around or hack, so zwift can’t be bothered.
You can create a free ride block and show the average watt.
See: https://youtu.be/KC5RWGrDE_s
You can use the bias button to increase or decrease the required watts.
That would mean you wouldn’t get segment timers and stuff as you would be in workout mode.
You can only change it by +/- 10% though which doesn’t give much of a range.
Yes but you should probably know what average you are aiming for. so if you aim for 200w you can go from 180w to 220w.
Maybe I haven’t used average watts that much I just follow the workout targets.
