I have a problem in the Ramp test, when I do it, it seems that the ERG mode doesn’t work for me. When I get to about 200W, I generally don’t feel the load, I spin as if I’m on the lightest speed and I’m driving on the smallest (heaviest) gear. For 240W, I have to have a cadence over 110 revolutions and it is questionable if it reaches 240W, instead of making it difficult for me, it becomes easier and I can’t reach those Watts. I tried to ride a mountain path and as I climbed more and more, it gave me resistance on the wheel
I ride MTB 1x12deore set 32 front and rear 51 largest cassette,
Running Zwift on a Win10 PC, and I use the Zwift Companion app for connection.
Using a Tacx Vortex Smart!
If you’re spinning out high gear, the easiest fix is probably a larger chainring (and a longer chain). Depending on your outdoor terrain, the bike may still be usable outside with bigger gearing. A 32x51 is quite a low gear - do you use it when riding outside? Where I live a 38x51 would be fine, and 38x11 high gear is considerably higher than 32x11.
