The previous version of zwift output about 100fps with Radeon RX 5700XT.
However, after the release of Yorkshire, the performance dropped to about 30fps in the same environment.
GPU usage is only about 55%.
I have tried several Radeon drivers and the results are the same, so I think the performance degradation is due to the zwift application.
Does this happen on other Zwifters?
I want to know what is necessary to get the GPU performance that I want.
Game Version: 1.0.39812
Launcher Version : 1.0.44
Radeon Software Version 19.7.5 / 19.9.1
Just for laughs, what happens if you start the game, then disconnect you networking? Does your fps go up? And what happens if you go into âjust watchâ? My fps has dropped recently in groups but my CPU and GPU show pretty low utilization 35% on the busiest core / 65% GPU load. The GPU isnât being pushed and I have no idea where the bottleneck is. Could be DDR3 1333 MHz RAM, but I doubt it as it was fine up until a couple of months ago.
Low performance is the same for both network disconnection and âjust watchâ.
Was this resolved? I had heard the 5700xt had OpenGL driver issues in the early days. Should be fixed with newer drivers but I havenât heard for sure that it was. This has been holding me off getting one of these cards.
I donât know the cause, but it has been resolved at this time.
AMD chipset driver: 1.09.27.1033
RadeonSoftware: 19.11.1
Power management plan: AMD Ryzen High Performance
In these configurations and settings, the CPU and GPU are almost 100%.
It keeps about 100fps for solo rides, about 30fps for races and group rides.
Poor english, sorry.!
Thank you.
I bought an AMD 5700 XT and found the exact issue you did. Using driver 19.11.3. Iâm currently downgrading my driver to 19.11.1 and am hopeful for a positive outcome like you have.
Edit: did not change. Still having the issue. Badly need Directx support for AMD GPUs.
I have a ryzen 1300x with an nvidia 1060 3gb âŚso a low/medium perfomance pc.
IN my case fps are blocked at 60 because i use an old 60hz monitorâŚ
if i ride alone 60fps are rock solid but when iâm in group ride/workout my fps drops at 30 or 40. IN eric min thanksgiving ride, in the initial part of the ride my fps dropped to 15 !!!
Even for my config cpu and gpu are always at about 50% of load even when fps dropâŚ
note in the following pic that my fps are low, about 40âŚeven if there are only 5/6 riders on screen. But it was a group workout and a lot of riders were behind me in that pic but it seems that is not the number of riders on screen that lower my fps in that way. When i ride solo with a TT bike i do not have drops with 10/15 riders on screen.
Is the power management set to High Performance or Ryzen High Performance?
By installing AMD chipset driver cleanly, Ryzen High Performance can be set.
My environment is a desktop, and the âBalancedâ setting seemed to limit both CPU / GPU.
Thanks for the answer.
I will check asap.
I canât remember if when i have installed w10 i ve installed motherboard drivers only or mobo + amd drivers.
iâve installed the last chipset drivers for my old 1300x but in the power profiles i only have Ryzen balanced and not ryzen high performance. Maybe it s due to the poor processor.
By the way i ve read that this can of setting should not put a limit to the max cpu load.
Even this morning, while a i was riding solo i have met a group of about 15/20 zwifters. They were riding in the opposite way but when i ve met them, fps dropped for some secondsâŚand cpu and gpu were under 40% of load
Yeah thereâs definitely an issue with this.
Iâve recently built a new pc for zwift with an ryzen 7 2700 and a nvidia gtx 2060 and in the group ride today avg fps was just over 30. This shouldnât be the case on a system like this.
Cpu utilisation around 8% and GPU 38% approx. It stays like this on âjust watchâ also, but at least with that fps is way above 100.
Since the same phenomenon has occurred in both Radeon and GeForce, I think there is a potential defect.
zwift should investigate this.
There is no defect. In large group rides youâre observing single core bottleneck because Zwift app relies on large number of concurrent, dependent on each other calculations (which canât be offloaded to other cores/threads). Your total CPU utilization may be low, but when you look closer youâll see one of the cores being near 100%. This therefore affects number of frames provided to GPU and its utilization.
The problem is that the single core usage is low.
Itâs not about multicore totals.
I believe that the problem is in the network, from Europe we have a latency with the AWS servers in California around 175ms and if you have to receive all the information from the riders who are in a group and the algorithm is not optimal, it will never consume all the resources of the CPU.
Greetings
It is completely unknown why a delay of only 100ms affects CPU processing.
(If it is correct, it is better to redesign the software design)
At the very least, it is not an explanation that the problem may or may not occur depending on the version.
There are other topics on low performance besides this thread.
If you can say that it is not a bug, I think that you should investigate logs etc. and give evidence that there is no problem.
It might by scattered between few cores (usage of each will jump up to 90-100% for few seconds). It simply doesnât get much better than 30-40 fps in big group rides on any equipment. Maybe some changes in the way Zwift app handles it are required, but for now it is how it is. On the screenshot: charity ride with Andre Greipel - over 6000 riders 25-60fps (capped at 60), image|690x437
So lets summarize. It is not a problem with 5700XT. Itâs CPU single core limitation. GPU canât be utilized when CPU doesnât provides it with frames.
Yes, connection latency might be part of the problem, although I didnât observe that.
Thanks Michal.
What I want to be clear is that my PC is currently running zwift with the expected performance.
(A snapshot of âzwiftalizerâ at that time is also included.)
No low performance issues have occurred.
However, similar phenomena are still occurring in other Zwifters, and we are talking about whether the zwift software, rather than the RX5700XT, has potential problems.
Now the goal point of this topic is unclear and may need to be closed.
