Low GPU utilization with AMD GPU
I tried upgrading my RX 550 4GB to a 580 8GB and performance was the same. 1440p resolution and logs show its using the ultra profile, but I get the same 30fps in an activity. I tried a 6500XT as well and got better FPS at 40+ but not great. All with a Ryzen 5500. I used some monitoring tools to record metrics and noticed really odd GPU utilization behavior. Jumping from 100 → 3 → 65 → 100 → 4 → 68 → 100% and doing that throughout an activity. Same results with both the 580 and 6500. I’m using the latest drivers.
Is Zwift compatible with AMD GPU’s?
Take a look at this zwift insider article if you haven’t already. Scroll down to CPU Bottleneck.
https://zwiftinsider.com/zwift-pc-guide-2/
Also, when you are assessing CPU utilization, you need to pay attention to whether a single core is maxed out. In Zwift it’s normal for most of the CPU to be unused while hammering one core to death. IOW a 6 core CPU with 17% utilization overall could be at the limit.
Thanks, it’s def CPU. When I’m riding by myself I get 60FPS + and 100% GPU utilization.
One thing you can do to get a little performance back is disable the Video Screenshots feature in Zwift if that’s turned on. It should be on by default with that CPU.
