The bottom line is if you’re fat then you can put out power with a lower w/kg and win a low category when those categories are based on w/kg.
If you’re skinny and try to keep up or beat them then your w/kg will go above the category cut off and you’ll get disqualified or promoted out of that category for being “too good” even though you had no chance of winning a race in that category.
That can rinse and repeat, especially if you train and improve, or you’ll just end up in a category you struggle to race in.
Heavier riders have the advantage.
There’s an obvious solution but one that is cheating. Presumably the race score based on results rather than w/kg should improve this.
I agree this is nonsense because the WKG threshold has nothing to do with racing score, and even in a CE event it can result in giving a DQ to a rider who isn’t upgraded so they just get another WKG in their next race. The problem is the moribund situation with ZwiftPower that results in the event organizer accidentally giving out DQs.
