Question regarding Zwift Ride compilation
Hello everyone,
Since the Zwift Ride package was recently no longer available, I ordered the Zwift Ride frame, the KickrCore and the Cog V2 individually.
I have now noticed that the connection between the frame and the KickrCore has a little play. Do I need to use adapters for this combination or just push the axle through the frame and the KickrCore and tighten it?
I have also noticed that a Zwift Cog (orange) is already included with the frame package. Is this the V2? Do I have it twice now?
I believe there are adapters for the trainer, likely came with the frame?
Yeah, send back the Cog you ordered individually and use the one that came with the frame.
You need to use the 142mm spacer with the cog for the frame. There should be a small spacer that goes on the drive side that goes over the nut on the cog and another spacer that has 142 marked on it that goes on the non-drive side of the Kickr.
The frame should fit snugly on the trainer. There should be no play.
Thank you very much!
