Program keeps crashing
Anyone having issues with zwift crashing with no error messages in the last few days? It’s crashed 5 times in the space of an hour. It’s updated twice in the past week, including today. (edit) Something def changed with the update today devs - The game crashes constantly after a few minutes. It’s not even useable. Last log below, wrote “removed” for URLs and xx in lieu of my data
[18:14:17 2023-04-24] Launcher: Auto Startup is Enabled.
[18:14:17 2023-04-24] Launcher: Launcher Version Number 1.1.6
[18:14:17 2023-04-24] Launcher: Initializing UI Components
[18:14:17 2023-04-24] Launcher: Initializing Tray Components
[18:14:17 2023-04-24] Launcher: Initializing Patcher
[18:14:19 2023-04-24] Launcher: Setting Login URL
[18:14:19 2023-04-24] Launcher: prefs.xml file found.
[18:14:22 2023-04-24] Launcher: Found Launcher URL.
[18:14:22 2023-04-24] Launcher: prefs.xml file found.
[18:14:22 2023-04-24] Launcher: Navigating to Login URL
[18:14:22 2023-04-24] Launcher: Checking for VerCur Override
[18:14:22 2023-04-24] Patcher: Found ff vercur override: Zwift_ver_cur.xml
[18:14:22 2023-04-24] Launcher: Starting WebView2 Initialization
[18:14:22 2023-04-24] Launcher: Displaying Main Window.
[18:14:26 2023-04-24] Launcher: WebView2 initialized
[18:14:26 2023-04-24] Launcher: Checking for Internet Connection
[18:14:26 2023-04-24] Launcher: Patcher Update Process Check
[18:14:26 2023-04-24] Patcher: Patcher Version Number: “1.3.1”.
[18:14:26 2023-04-24] Patcher: Local download path set to "C:\Users\xx\Downloads\Zwift".
[18:14:26 2023-04-24] Patcher: Server URL path set to “removed/gameassets/Zwift_Updates_Root/”.
[18:14:26 2023-04-24] Patcher: Local update path set to “”.
[18:14:26 2023-04-24] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[18:14:26 2023-04-24] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[18:14:26 2023-04-24] Downloader: Created file handle for “C:\Users\xx\Downloads\Zwift\Zwift_ver_cur.xml”.
[18:14:26 2023-04-24] Downloader: Created file handle for “C:\Users\xx\Downloads\Zwift\Launcher_ver_cur.xml”.
[18:14:27 2023-04-24] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[18:14:27 2023-04-24] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[18:14:27 2023-04-24] Downloader::Update m_filesCompleted.push_back path=C:/Users/xx/Downloads/Zwift/Zwift_ver_cur.xml success=1
[18:14:27 2023-04-24] Downloader::Update m_filesCompleted.push_back path=C:/Users/xx/Downloads/Zwift/Launcher_ver_cur.xml success=1
[18:14:27 2023-04-24] Patcher: Completed downloading server XML version files (Game & Launcher).
[18:14:27 2023-04-24] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[18:14:27 2023-04-24] Patcher: Local version is “1.0.109673”.
[18:14:27 2023-04-24] Patcher: Server version is “1.0.109673”.
[18:14:27 2023-04-24] Patcher: Local manifest is “Zwift_1.0.109673_0e59edd2_manifest.xml”.
[18:14:27 2023-04-24] Patcher: Server manifest is “Zwift_1.0.109673_0e59edd2_manifest.xml”.
[18:14:27 2023-04-24] Patcher: Server manifest file checksum is “891756609”.
[18:14:27 2023-04-24] Patcher: Server ver_cur checksum is “2023843912”.
[18:14:27 2023-04-24] Patcher: Local Launcher version is “0.0.0”.
[18:14:27 2023-04-24] Patcher: Server Launcher version is “0.0.0”.
[18:14:27 2023-04-24] Patcher: Launcher URL for updating self is “removed”.
[18:14:27 2023-04-24] Patcher: No update available, deleting temp files…
[18:14:27 2023-04-24] Downloader::ForgetCompleted path=Zwift_ver_cur.xml
[18:14:27 2023-04-24] Downloader::ForgetCompleted path=Launcher_ver_cur.xml
[18:14:27 2023-04-24] Launcher: Launcher Update Process Check
[18:14:27 2023-04-24] Launcher: Checking for Game Update Availability
[18:14:27 2023-04-24] Launcher: Game Update Not Found
[18:14:42 2023-04-24] Launcher: ZwiftApp.exe is not running.
[18:14:42 2023-04-24] Launcher: Starting Zwift App.
[18:14:52 2023-04-24] Launcher: ZL has a valid process pointer and the flag HasExited is False.
[18:21:33 2023-04-24] Launcher: DoUpdateCheck() Called.
[18:21:33 2023-04-24] Launcher: ZL has a valid process pointer and the flag HasExited is True.
[18:21:33 2023-04-24] Launcher: Starting Update Check.
[18:21:33 2023-04-24] Launcher: prefs.xml file found.
[18:21:35 2023-04-24] Patcher: Found ff vercur override: Zwift_ver_cur.xml
[18:21:35 2023-04-24] Launcher: Checking for internet connection.
[18:21:35 2023-04-24] Patcher: Patcher Version Number: “1.3.1”.
[18:21:35 2023-04-24] Patcher: Local download path set to "C:\Users\xx\Downloads\Zwift".
[18:21:35 2023-04-24] Patcher: Server URL path set to “removed/gameassets/Zwift_Updates_Root/”.
[18:21:35 2023-04-24] Patcher: Local update path set to “”.
[18:21:35 2023-04-24] Patcher: Kicking download of “Zwift_ver_cur.xml”…
[18:21:35 2023-04-24] Patcher: Kicking download of “Launcher_ver_cur.xml”…
[18:21:35 2023-04-24] Downloader: Created file handle for “C:\Users\xx\Downloads\Zwift\Zwift_ver_cur.xml”.
[18:21:35 2023-04-24] Downloader: Created file handle for “C:\Users\xx\Downloads\Zwift\Launcher_ver_cur.xml”.
[18:21:35 2023-04-24] Downloader: “Zwift_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[18:21:35 2023-04-24] Downloader::Update m_filesCompleted.push_back path=C:/Users/xx/Downloads/Zwift/Zwift_ver_cur.xml success=1
[18:21:35 2023-04-24] Downloader: “Launcher_ver_cur.xml” downloaded successfully (manifest checksum not provided, i.e. -1).
[18:21:35 2023-04-24] Downloader::Update m_filesCompleted.push_back path=C:/Users/xx/Downloads/Zwift/Launcher_ver_cur.xml success=1
[18:21:35 2023-04-24] Patcher: Completed downloading server XML version files (Game & Launcher).
[18:21:35 2023-04-24] Patcher: Fetching version attribute from file: “Zwift_ver_cur.xml”
[18:21:35 2023-04-24] Patcher: Local version is “1.0.109673”.
[18:21:35 2023-04-24] Patcher: Server version is “1.0.109673”.
[18:21:35 2023-04-24] Patcher: Local manifest is “Zwift_1.0.109673_0e59edd2_manifest.xml”.
[18:21:35 2023-04-24] Patcher: Server manifest is “Zwift_1.0.109673_0e59edd2_manifest.xml”.
[18:21:35 2023-04-24] Patcher: Server manifest file checksum is “891756609”.
[18:21:35 2023-04-24] Patcher: Server ver_cur checksum is “2023843912”.
[18:21:35 2023-04-24] Patcher: Local Launcher version is “0.0.0”.
[18:21:35 2023-04-24] Patcher: Server Launcher version is “0.0.0”.
[18:21:35 2023-04-24] Patcher: Launcher URL for updating self is “removed”.
[18:21:35 2023-04-24] Patcher: No update available, deleting temp files…
[18:21:35 2023-04-24] Downloader::ForgetCompleted path=Zwift_ver_cur.xml
[18:21:35 2023-04-24] Downloader::ForgetCompleted path=Launcher_ver_cur.xml
[18:21:35 2023-04-24] Launcher: Checking Launcher Version.
[18:21:35 2023-04-24] Launcher: Checking for Game Update.
[18:21:35 2023-04-24] Launcher: No Update found.
Operating System: Windows 11 Home 64-bit (10.0, Build 22000) (22000.co_release.210604-1628)
Language: English (Regional Setting: English)
System Manufacturer: GPU Company
System Model: GWTN156-12
BIOS: CC-BI-15.6-XA133PR200-LE50A-228-I (type: UEFI)
Processor: AMD Ryzen 3 3250U with Radeon Graphics (4 CPUs), ~2.6GHz
Memory: 4096MB RAM
Available OS Memory: 3534MB RAM
Page File: 4594MB used, 3804MB available
Windows Dir: C:\windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.2.2
DxDiag Version: 10.00.22000.0653 64bit Unicode
Card name: AMD Radeon™ Vega 3 Graphics
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x15D8)
DAC type: Internal DAC(400MHz)
I think your launcher is out of date so you could try updating it. It should be 1.1.7.
I’m surprised that you say the game has updated multiple times. There have not been multiple updates in the last week. That makes me think you might want to try a clean reinstall. (You can ignore the part about backing up the “cp” folder.)
If that doesn’t help, look for clues in the Windows Event Viewer.
I received an update this morning but it’s not a recognised one in the incremental list. Ie. Its not 1.34.1
No idea what its done but probably added some assets for forthcoming races or events and not a bug fix.
I already had 1.34, but on my last login I got a quick windows notify update for something called like ‘zwifthelper.exe’ – happened really quick. No idea what it was.
By the way, if you only have 4GB of system memory, you might want to upgrade that to the minimum 8GB.
Did that appear in the bottom left of the login box? If so then i think that’s always there. Certainly something i see anyway.
Appreciate the information and tips. So here’s an update. I reloaded the zwift program per directions and it updated to current version. I also made sure that windows was updated. Additionally, I updated the chipset drivers. But the problem persists. I now know that it has something to do with my GPU, as an error reporting window pops up…well it did. At first, I just updated the GPU driver and the game would crash even faster, within 3 minutes of being in a map whether cycling or just watching. So i rolled back the GPU (display adapter) driver and it would still crash but it took much longer… @ 15 minutes after getting into a world. Then I updated with a chipset driver, as its a CPU/GPU type of thing, and now the rollback option for the GPU (display adapter) is subdued and its still crashing within 3 minutes. It crashes hard, if I don’t CTRL-ALT-DELETE fast, it will black screen and then I have to do a hard restart. So I really need some help because I’ve hit the extent of my capability. I’ve been using my laptop for the last 3 or 4 months with no issues and then this started about the 13th or 14th.
I’ll be happy to post more logs but which ones should I pull?
Thanks in advance!
James
Run the Windows Event Viewer and look for errors there. https://www.xda-developers.com/how-use-event-viewer-windows-11/
