last week bought New tacx flux 2 trainer. When using Zwift or using Tacx even 1%climbing feels sooo heavy that I really have to push very hard. Note I am already schifting very Light at that moment. At this moment I Can’t even ride Richmond or a flat race pffff have tried everything but nothing is working
Contacted garmin support but no reaction yet so really bad feeling. How can this be fixed cause really bad feeling ecperience uptil NOW!!!
Are you connecting via ANT+ ?
If so make sure when you connect you choose the option for FEC if it appears.
Also what trainer difficulty have you set it to? Even 100% shouldn’t be an issue at a 1% gradient.
Also ensure you upgrade to the latest firmware.
You could try a factory reset. Here are the instructions for the Neo, not sure if it’s the same as the Flux.
https://tacxfaqx.com/knowledge-base/resistance-factory-reset/
Regards
Hi Stuart Thx for your reaction. I use normal blue tooth. Calibration done by tacx utility app en latest firm ware done. I ll have a look at the factory reset. The gradiënt scale I adapted it to 50% but like you say no difference and friends of me who also have a tacx flux 2 don’t have these issues… Some people say I have to adapt my ftp but i think this has nothing to do with my problems. Anyway Thx i ll try the reset. Kind regards Sven
Hi Stuart. Pfff the isotonic menu is not popping up… Think it’s only for the neo. I am google now but not found yet for the flux 2…
If you are moving from a wheel on trainer to a direct drive then you will see a difference in your FTP. Mostly it’ll go down owing to the higher accuracy but sometimes it’ll increase (you hope).
If you are struggling to turn the pedals at 1% then there is something wrong.
Have you an option to connect via Ant + to see if it is a communication error?
Sven,
Were you able to fix?
Could you please share what did you do?
Thanks!
Sorry just read your message. No fix went to wahoo and now it’s ![]()
I had the same problem. I installed the app on my phone and upgraded the firmware, then recalibrated and the problem was solved.
