Problems since update with my Elite Direto :(
Thanks Gerrie.
I did calibrate both.
Amazing
Hi Stan. I tried to calibrate in both MyEtraining and zwift. The MyEtraining went fine, however I can’t get past 4mph in zwift so the calibration doesn’t complete properly. I tried 173 and 2070 in the tyre size and restarted the trainer and app to make sure everything had a fresh start. Still not working on zwift. Have I missed something?
@Andy_White_BCCC @Stan3647_Backus Any news about it? I have the same issue with Elite Direto: no resistance on flat routes. Also with a high cadence, very low power. Thank you
Elite concluded that they were unable to work out what the problem was with the trainer even after I had proved that the issue was not dur to zwift as it could be reproduced with the elite app. My direto now sits in a corner of the garage and I have a tacx neo that has been perfect. Sorry I can’t give you better news, and my views on Elite customer support is not very positive.
It’s a long story.
First of all I contacted Elite and they send me a procedure to tighten the belt and install some new software.
But meanwhile I also contacted the store where I bought the elite.
Some days later the resistance was gone. After I opened the elite it seems the belt broke. Elite send me a new belt with procedure but I chose to return the Elite to the store and claimed guarantee. They couldn’t fix it so they send me a complete new elite X😎
@Andy_White_BCCC @Stan3647_Backus thank you very much for the replays! I have no issues with the belt, it works fine in ERG mode and on the uphills too, only problems with the flat routes.
With Direto X are the resistance problems disappeared?
Yes.
No problems at All.
I think it is a Zwift problem too. I experienced that on my computrainer from the beginning with Zwift. Zwift is supposed to signal to your device and increase the wattage but doesnt on some steep climbs. I seen the problem occurring when there alot of riders going up a climb, I believe their serviers are overloading and giving us that symptom of throttling the power too low or not controlling the smart trainer.
I’ve lost all hope with my Direto and Zwift. I can get a good workout on Zwift but unless its a hilly race/group ride I cannot sprint put power down on the flat 52/11. Always spins out and end up doing 100rpm to stay with a group. I love zwift and elite and zwift just blame each other. Its just not good enough. A TRAINER IS A HUGE INVESTMENT and if its wasnt for being able to get some sort or workout from the trianer id o binned it long ago. but the experience is only 50% for me. I can ride on the flat IRL in the 52/11 and have no chance of spinning out. I have good sprint on me but Zwift just wont let you do it. During ZA workouts- sprint intervals of 10secs i start with an avg of 1000 watts and end up with like 212watts as im doing 130rpm in 52/11. Its very frustrating. doubt il be buying an elite again. however i worry if wahoo or tacx users have similar issues. :frowning:
the problem is from Zwift calibration system. It like a virus… No more resistance with my elite direto since i try calibration (étalonnage). Now it is impossible for me to enjoy Zwift. Can anybody tell us what is wrong with my precious equipment ??? even after going on the elite app to calibrate. still my Zwift is not the same. use to have ftp at 266 now it is 198ftp . must be my 40 haha
Hey Eric,
So Elite have been onto me to send them lots of logfiles which I haven’t had time to do since i have my work around to solve my issue of spinning out on flats/no resistance on flats. What i did was. Disconnect all sensors from zwift and turned off my apple tv (usually leave it on standby) connected my phone to elite app, started level mode and adjusted resistance for few mins. Switched off trainer and disconnected and closed app. Started apple tv and using my iphone as bluetooth connections powered my crank based power meter as power, and cadence and direto as control. Now its works well for me and i can hold proper numbers and sprint etc and can finally race. However this setup wont work for ERG mode for me. So what i do is for any workouts is, i pair the trainer as power and control and it works fine. Otherwise i use my powermeter for races and group rides. The first half of my ZA 2020 rides where pointless until i sorted out resistance. But if you have a powermeter hopefully that will be possible for you
I should say Elite are fanatastic and replying to you, its a credit to them. Just my trainer was out of warranty before i knew how these things all are supposed to work on user level. Just from where i stand they should have a clear instruction book for each setup, i.e apple tv, mac. Windows, android and iphone/ipad given the forums internet is littered with direto complaints. As ive had to experiment to make mine work well. For ages i was getting dropped on every race with flat sections. With hilly races i was okay. So I’m afraid to blow on it and stop it working. To be fair. I think zwift and elite need to focus on sorting out a software fix together or better still lets have trainers that are hardwired and we wouldn’t have these issues🙈
