Problem watt value sensor
I’m noticing that my watts after training are not accurate; they are much lower. I use the Elite Direto XR-T trainer.
As soon as I log into Zwift, the system searches for sensors and automatically detects them, but I can’t access the option to set the power sensor. Sometimes, a wrench icon appears, but it disappears quickly, and I can’t click on it. That should be where the calibration is done.
Is there a way to access this setting?
Use the Elite app for calibration. (Do not use Zwift for calibration.) When done calibrating hard close the Elite app. For Zwift, never connect the trainer to Windows…only to Zwift.
When you do the calibration through the Elite MyEtraining app, make a note of the four-digit calibration number that appears on screen. Compare this number to the factory calibration number written on the label ok the underside of your trainer.
The two numbers should be extremely close, otherwise there’s a problem.
I think Steve means Elite MyTraining App
I certainly did! Thanks Mike - edited.
