I have tried everything from lowering tire pressure to max 110psi. When I hit the climbs over 6% - and I try to push the power, I often get slipping. IT is a drag as I often have to stop and start again. I was doing the climb this weekend and had to stay below 200W otherwise slipping.
I us the tires on my bike- not specific for trainer. They are about 6 months old Michelin Pro 4. I didn’t think about that- I have an extra set of wheels I could use. Do you think that would solve the issue.
Yes I turn the tension 2 clicks- tried 3 clicks even.
Really road tires and trainer tires are 2 different animals. You should really get yourself a trainer tire, i had one when i had a wheel on trainer they don’t slip as much. Also using tires that you would normally use on the road, is kinda dangerours. You weaken the sidewall of your tire on the trainer.
Matt is absolutely right, I couldn’t agree more. Getting the right tire is the key, if you’ll still experience tire slip you can also check the resistance settings in Zwift where you can lower it to solve the issue.
Thanks for your enquiry, keep us updated and Ride On!
You can also force the knob to turn by pressing IN on the knob while you turn it. I have a new-to-me Powerbeam I had to do that with and I suspect I need to go ahead and order a new clutch knob thingy. Or just what I tried …
