Hi everyone,
I recently installed my Elite Justo 2 with Zwift Cog and Click V2. Everything seems to work fine overall, but I’m noticing some strange behavior when I try to push higher cadences on high virtual gears.
For example, while riding Zwift Camp: Baseline - Power Punches (Workout 2), during the Free Ride mode and using gear 24 at 140-160 rpm, my power output maxed out around 520 W. I was expecting much higher numbers, considering this gear ratio and cadence. It feels like resistance is not scaling correctly with virtual gearing.
My setup:
Elite Justo 2 (firmware up to date)
Zwift Cog + Click V2
Power source / controllable / cadence: all set to the Justo 2
Zwift basic steel frame
I’m 110kg and 181cm.
I’ve already done a calibration via the My E-Training app, and the firmware is updated.
Has anyone experienced something similar? Is this expected behavior with the current virtual shifting implementation, or could this indicate a configuration issue?
Thanks in advance!
José
