hi alle my power device is not working any more from the day the new update., were on
More info is needed to better assist you in resolving your issue.
Hi Patrick, by “power device” I believe you are referring to the platform you are running Zwift on, rather than your trainer.
If this issue is indeed related to the update, one reason could be that the update you’re referring to was not supported by the device you are running Zwift on.
If you’re using a laptop, you can try locating its specific driver updates online. By updating drivers, you may bring things up to speed so that Zwift will run.
Otherwise, your device may no longer meet the minimum requirements.
Hope this helps ![]()
