If the test was done at the 117w for the fictional athlete then the rpm would be between 65 and 70 rpm.
No, you are assuming that your W/kg reads across to all riders. Recovery wattages and W/kg varies drastically by rider. You can’t just change the variables of the scenario to make a point. The example was a 100 kg rider at 85 watts, not a 94 kg rider at 117 watts… nice try though.
The test was to see if ± 80w is feasible going up that KOM. And yes it is.
The position being taken is that climbing uphill does not promote recovery, not whether it was possible, but your “test” still didn’t prove anything. It proved that you, a lighter rider than the example had to ride at 53 RPM to get up the climb. A GROSSLY Sub-optimal cadence, especially for recovery
I am happy to do the same test at 117w at 65-70RPM.
That would be an exercise in futility, as you clearly aren’t following the premise here.
I find it very funny that you continue to come back to this thread and double down on your position with attempted brute force. Respectfully, you are demonstrating that you are out of your depth on this subject. You are generating arguments based on anecdote and supposition, not on scientific fact. And for what reason? You already ceded that the flat route is ideal. Both @Mark_Crane_TOG_G_65y and I have stated that while possible, performing this ride at a recovery pace is going to be VERY difficult for a good segment of riders – for some, it WILL be impossible without changing their trainer settings. I can only glean that you are here simply to argue at this point.
You literally went out of your way to do a ride with the segment so you could snip it into this forum and call it “science” without realizing, that in doing so, you actually validated my statement to which you replied. If what you are looking for is the last word on the matter – which is what I am beginning to suspect – by all means, feel free to take it. I am confident that, at this point, my position speaks for itself, and any future participants or viewers of this thread can apply critical thinking to discern what position resonates with them as accurate.
I will not be furnishing any more replies to you on this matter, enjoy your weekend.
