[PC] Zwift crashes mid training everytime
Hi there!
I’m a rookie user, and just started Zwifting. I did 3 full trainings now, and the last two Zwift crasht mid-training. After the first crash I made sure the second run everything was updated, fresh reboot, no apps running in the background… and still a complete freeze after around 30 minutes in (very annoying).
I’m running quite a new PC, 1440 resolution, full screen on a AMD Radeon RX 5700 XT. I’m connected with ANT+ (licensed Tacx antenna). It’s around 1,5 meters (5 feet) away from the Tacx.
I’ve exported my events from the viewer (but both support links for chat and email do not seem to work?).
Anyone a hint or tip? I’m also connected to the internet by wire, no known issues with my connection (200mbit).
In the log I just see:
[8:37:38] NETCLIENT:[WARN] UDP connection timeout (7 so far), reconnection attempt 7
[8:37:38] NETCLIENT:[INFO] Connecting to UDP server…
[8:37:38] ANT : Rx Fail on channel 3
[8:37:38] ANT : dID 727878 SW Revision 11523 SerialNum 6982
[8:37:42] ANT : Rx Fail on channel 2
[8:37:42] ANT : Rx Fail on channel 1
[8:37:43] ANT : Rx Fail on channel 1
[8:37:44] ANT : dID 1121094 SW Revision 11523 SerialNum 6982
[8:37:45] ANT : Rx Fail on channel 2
[8:37:45] ANT : Rx Fail on channel 1
[8:37:46] ANT : Rx Fail on channel 2
[8:37:46] ANT : dID 727878 MFG 89 Model 2900
[8:37:47] ANT : dID 727878 MFG 89 Model 2900
[8:37:48] ANT : Rx Fail on channel 3
[8:37:48] ANT : Rx Fail on channel 1
[8:37:49] ANT : Rx Fail on channel 3
[8:37:49] ANT : Rx Fail on channel 2
[8:37:52] FE-C 240 received
[8:37:54] ANT : Rx Fail on channel 1
[8:37:54] ANT : Rx Fail on channel 2
[8:37:55] ANT : Rx Fail on channel 2
[8:37:55] ANT : dID 727878 SW Revision 11523 SerialNum 6982
[8:37:56] ANT : Rx Fail on channel 2
[8:37:57] ANT : Rx Fail on channel 3
[8:37:59] ANT : Rx Fail on channel 2
[8:38:00] ANT : Rx Fail on channel 2
[8:38:00] ANT : dID 1121094 MFG 89 Model 2900
[8:38:01] ANT : dID 1121094 MFG 89 Model 2900
[8:38:01] ANT : Rx Fail on channel 2
[8:38:02] ANT : Rx Fail on channel 2
[8:38:03] ANT : dID 727878 MFG 89 Model 2900
[8:38:04] ANT : Rx Fail on channel 2
[8:38:04] ANT : Rx Fail on channel 3
[8:38:05] ANT : Rx Fail on channel 2
[8:38:05] ANT : Rx Fail on channel 3
Same problem here, Windows 11, Radeon 5700XT. Trying driver downgrade now to radeon-software-adrenalin-2020-21.10.1-win10-win11-64bit-oct5.
