I cant pair the velocity and cadnece sensor.
It doesnt appear on the search screen,
What happens??
I use a garmin sensor
What happens??
What device are you running Zwift on? If it is an iPad, iPhone or AppleTV they are Bluetooth only and the Garmin sensors are probably ANT+.
Hi Paul, thanks for the quick answer.
I tried with two devices separately; iphone and pc(windows).
I think that my sensors are bluetooth because I have the edge 820, right?
The Garmin Edge can receive ANT+ signals.
If you look on the sensors it should have either a Bluetooth or ANT+ icon (or both in some cases).
If they are Garmin sensors more than likely they are ANT+.
ok! I will try with a ANT+ receiver, thanks for your help!
Zwift on the iPhone is Bluetooth only.
If you are going to use ANT+ on the computer make sure you are also using a USB extension so your can get the dongle as close to the sensors as possible.
nice! thanks again!!
all the ANT+ adaptors are exhausted everywere
jajaja
well, we will try, txs
They are available here: ANT+ Bundle - Zwift
