Update Request: in the device pairing screen, move the OK button to be left justified with the left edge of the device selection panes, and below the Heart Rate device pairing selection pane.
In the Paired Devices screen (MacOS), the OK button is in the same location as the RIDE button in the “World Choice” / “Ride Type” / Device Status screen.
If one clicks the OK button too quickly—ie double click—one is launched directly into the game environment, without being able to set a world/course/workout.
This is poor UI design: frustrating to users who need to select a world, route, or workout, after pairing devices, before launching into the game.
I think this is an interesting observation, and may explain why in other threads I have seen comments about being dumped directly into a world and course, instead of being able to choose. Personally I have never experienced this (Apple TV), but I can certainly see how it could happen, especially since a ‘double click’ is such a common habit.
I use windows so it may be different, but once I have paired all my devices I don’t have to press OK, a countdown will start and it will go to the Home screen.
I agree with @Nigel_Tufnel, this might explain the other user comments in other threads.
in my experience, it’s not always clear if your first click worked or not. you click, wait a few seconds, nothing happens, so you click again, and then miraculously both clicks register in quick succession.
There is another awkward possible overlap of buttons when returning from the garage to go back to your riding screen and having to pick the back button.
I have accidentally hit the end ride button instead and there is no option to go back from that.
I have only done this once because I messed up my ride big time so learnt the hard way.
Has anyone else made that mistake or am I the only fool…
Cheers Gerrie,
in my disappointment I didn’t notice that.
That makes me feel even more stupid than I did in the first place.
Thanks for making me feel even worse. LOL
LOL that was not my aim… to your credit that back button is very small.
@_Troy I assume you use ATV, do your paring screen also do the count down once you paired all your sensors like on windows. (as I mentioned in my first post)
It happens to me when my computer lags slightly, so it isn’t a double click just clicking again because it doesn’t look like the computer registered the first one.
It is probably a hardware issue with slower PCs but moving the buttons would solve it - for me at least!
I came here to make the same request.
On my mac, it’s quite slow starting up and I often click the ok button twice and then start riding straight away… it’s so stupid that the buttons are directly behind each other.
Or just dont have a world auto selected. Then it would allow the process 1 step… but would be so much nicer.
So may small issues which could be solved. Please please so some of them.
Mike, unfortunately that is not fully right - there is a long existing bug (like for years!) in the MacOS version that requires you to perform a double click (although it should only be a single click). Unfortunately Zwift seems to be uncapable or unwilling to solve this issue. Very frustrating!
