Not finding erg mode
If I do a workout erg mode is not showing ing game to put it on or off ? Where is the setting to select erg mode ……
Hi @Daniele_Manca, welcome to the forums! This is Monica from Zwift.
Thank you for bringing the ERG mode issue to our attention. I understand how important it is for you to resolve this problem. Here are a few steps you can take to troubleshoot the ERG mode:
  1. Ensure your trainer has the most up-to-date firmware. Firmware updates can usually be installed through the manufacturer’s app (e.g., Rouvy, Tacx Utility, Wahoo Fitness, etc.).
  2. Perform a spindown calibration. This can be done either in Zwift or through your trainer’s mobile app, if applicable.
  3. Check your trainer’s pairing status. Make sure it is paired with Power, Cadence, and Controllable, and that you are using either BLE or ANT+ for the connection.
  4. If you’re using BLE, check the signal strength to ensure it’s strong.
  5. If you’re using ANT+, make sure you are pairing with ‘ANT+ FE-C’.
For additional information, please refer to the relevant article. If you continue to experience issues, please don’t hesitate to contact us.
