Hi, why is it that sound only can be hear using jack headphone and Bluetooth headphone but not in the ipad speaker?
Are your Bluetooth headphones automatically paired to your iPad whenever you turn it on?
Hi, my wife found out the soft botton switch was off. Thank you for fast answer
Nice! Let us know if you have any other questions.
Hi I’m new. I read the stream and turned my iPad on and off (as well as my iPhone) … no sound using Zwift but no problems with any other app. Suggestions?
It’s time to clean the charging stand. There may be no speaker sound if it has dust on it or it is a bit corroded. This problem happened to my old iPad. I only know after Google that this issue will happen on iPad models or PC. You need to take a toothpick and scrape it off a little bit. The iPad thinks it is connected to the speaker base. Gook luck.
