No resistance on climbs
I run a elite direto and apple tv 4k yesterday everything was working fine, but today while riding Richmond there was no resistance on the climbs. I unplugged and rebooted everything and started again but still had the same problem. To rule out a fault on my trainer I replicated a climb using the My-Etraining app and everything worked a treat. Can anyone shed some light on this.
Al.
Did you move the Trainer Difficulty slider to “Off”?
I don’t think so but will check that tomorrow.
Thanks Darren.
Did the trainer connect with ANT+ FE-C?
I have a Direto X and sometimes it pairs Controllable with “Elite Real Trainer” instead of ANT+ FE-C
When that happens, the resistance don’t work.
It connects to apple tv 4k box using Bluetooth only, and I’ve been using this system for several months without any problems. Today there was a definite change in resistance from tarmac to cobbles and descending also felt normal. But on the climbs there was no change in resistance at all unless I changed to a higher gear. As it worked perfectly on Elites software was it just a zwift glitch???
Thanks for your reply Ben.
Did you end up finding a solution here? I have the same issue
I noticed on my Tacx that apparently it’s listed under controllable both as a BT-device and an ANT+ device (and as ANT+ FE-C separately) if I recall correctly. Fortunately it keeps track of the ID:s of the last devices used for various purposes
