Hi I’m using iPhone but there is no spanner appearing to calibrate footpod when I launch Zwift
I don’t think you can calibrate the Apple Watch as a Run Speed source.
Have you tried pairing the Zwift RunPod as a speed source and see if you have the option to calibrate?
Ah, that may be it!! I will see if can remove Apple Watch for speed, I assume the foot pod would be more accurate for this since it’s on my foot.
Paul is correct, the Apple watch has no calibration option because it’s not a foot pod and works differently. You should use the Zwift RunPod since you have that.
@FRiC You win the post of the day. ![]()
Hi all
I seem to be missing the spanner icon on zwift ,im using an apple box with the zwift app how do i get it back.
