since a week, I cannot enable or disable ERG mode on workout since the button to activate it is just gone.
I update the program to the latest version Version : 1.0.61217
As shown in the screen shot, the button is gone
Anyone ??
Hi, I has this problem too this morning. On android app I could disable it, but then the button to enable was not available. Looked on windows app and not possible there either. This was during a work out.
Any ideas anyone?
Cheers
It’s gone for me too on my MacBook Pro. However it does show on the Companion App
Happened since the latest s/w update
Hi @Robin_Ossie_Osborne. Thanks for sharing your concern on this space, this is Juan from Zwift I understand how worrying it is for you not to see the ERG mode button.
I hope you don’t mind helping me by sharing the following info.
Have you recently changed the way you connect your trainer? I mean, Is your trainer paired with Controllable via connections other than Bluetooth, such as the ANT+ FE-C channel or Wahoo Direct Connect?
What trainer do you use?
Have you tried doing a fresh installation? Sometimes when an update is done, some errors and glitches may arise due to it not downloading properly. If you want to try it, please click on this link.
On the other hand, If you would like to receive personalize assistance, please contact us. We will be happy to help.
Hi Juan,
I haven’t change the way I connect it’s via wi-fi (lead to the hub).
I use a Wahoo Kicker V5 (I think as it has Wi-Fi Direct using a connector.
I’ve rebooted my MacBook and restarted everything but still no joy.
Can you help.
All the best
Robin
What happens if you pair the trainer via Bluetooth or ANT+ instead of Direct Connect? Have you rebooted all of the network equipment that the Direct Connect device is connected to? I would unplug the Direct Connect device from the trainer and then pair it, see if there is any change.
