No Drops added when using Apple TV
I’ve completed 4 rides (2 on the 29th and 2 on the 30th) using Apple TV and the drops were incremented correctly during the game, but when starting the next ride they had reset back to the value from my last ride using an Ipad. Each time the bike was also reset to the Zwift Steel frame and not my usual Aethos. there are images in my feed where the drops are higher than my actual score.
This is due to being logged in on multiple devices. The safest solution is to delete the game from the device you’re not using, but it’ll probably be OK if you just make sure the app is terminated on the device you’re not using, or power off the device.
thanks Paul, yes, just had the same update from support… just need to make sure it isn’t running on the ipad when i use the apple tv (i have to keep both versions depending on where in the house i’m riding). i know for next time! doh!
Just be sure to force-quit the app after each session on whichever device you use. Simply closing it (putting it into the background) often isn’t sufficient.
