That’s great, thanks Paul, got it to connect now, not sure how but now the ERG mode won’t work, no problems ever then all at once
Check you have FE-C option enabled on the pair screen Jez.
Me too. Running Zwift on a MacBook with the same sensors I’ve used for years: Wahoo Blue SC and Wahoo Blue HR. Last night after the update Zwift could not see my HRM. It works fine with the Wahoo apps and Strava but Zwift lost it and searching from the app couldn’t find the sensor.
i’m having this issue as well. None of my devices will recognize my Kickr, including the ZML. Running Bluetooth through Apple devices. Worked fine for about four months, and now it has been doing this for about a week.
Edit: it does, by the way, connect through the Wahoo utility app, so it is starting to look like zwift issue to me.
Same here - since the last update it won’t find anything - even my HRM - useless and yet you’re still happy to take my money ![]()
I tried everything but still no joy but it is now sorted and it turned out to be because my WiFi signal was too weak
Still no answer from Zwift. The update from last week didnt solved this problem.
Niels,
Did you try the update release on the 27th of Feb?
Can you give a run down of your setup.
