Is this new or am I late to the party?
Haven’t seen that before…
That’s what you see if you bypass the launcher and run the game manually. Assuming you set the game going normally, there’s some problem preventing the launcher from logging you in. Close the game down (including the launcher from the system tray) and delete the folder(s) found in \AppData\Local\Temp\Zwift. Then try again. You’ll need to log into the launcher, because you have deleted your credentials.
