My right controller constantly shifts up and I can’t stop it
My right play controller repeatedly shifts up until it can’t go up any further. I can’t change down using the left one, it’s stuck in the highest gear. Any suggestions?
Try holding down the Z button for 30 seconds to reset the controllers.
However, it’s probably sweat ingress causing damage to the controllers internally, so if the reset doesn’t work (and do make sure the firmware is up to date) and you’ll need to contact Zwift support - support@zwift.com
Hi @Peter_Longthorne! Welcome to the forums! I’m Francisco from Zwift Support.
I’m sorry to hear about the trouble you’re experiencing with your controllers. Let’s work together to resolve this issue and get things running smoothly for you.
I’m going to follow up on your case in a one-on-one conversation by email so, keep an eye on your inbox.
Zwift controller also shifting up by itself…..if you work on the solution publicly the next guy can find the answer without contacting support :slight_smile:
The reason to contact support is you probably need it replaced if it’s under warrany
