My LBS gave me an ANT+ USB dongle for my Fenix 3HR - How to Pair?
I recently bought a TACX Neo 2 and I have set this up and everything is working fine. I currently monitor my heart rate with a Garmin Fenix 3HR. For this they also gave me a Garmin USB ANT+ dongle to have it connect through my laptop (Macbook Pro) to the Zwift App. I have not been able to find any suitable instructions on these forums or in general.
Most reference the use of the Broadcast HR function but all of the reply posts I have read say this does not work.
Can someone provide a definitive step-by-step process to connect my Fenix 3HR to Zwift? Or alternatively a link to something?
Jon
Can you tell me step-by-step what you have tried?
I have tested the Fenix3HR and it work over ant+
I have the ANT+ USB dongle in my Macbook Pro via a USB-C adaptor. I log into Zwift. I set my Fenix 3HR to “Broadcast HR” > Now. In the Zwift App I ensure my Tacx Neo 2 is connected, along with the cadence sensor etc and then click to search for my Heart Rate Monitor. It doesn’t come up in the list.
The point I am making is that it seems to miss the important step of ensuring the ANT+ dongle is connected.
On the packaging it just say “go to www.connect.garmin.com/start/” and follow the instructions - but there are no specific instructions that I can see.
Make sure Garmin Connect is not running on your Mac.
Thanks - I’ll give that a shot when I get back home!
I just tested on my system (Windows 10 Garmin Fenix 3HR)
Fenix 3HR = Settings > Sensors > Wrist Heart Rate > Broadcast HR > Now (on the watch it show my HR and the current time.
Zwift = Search for Heart Rate > Found Heartrate strap XXX. Started to ride and Zwift and Fenix 3HR show the same number.
Thanks Gerrie… Maybe I missed a step. I will try again when I get home on Friday.
Make sure the ANT+ dongle is working in Mac OS and that Zwift is using the ANT+. There should be an ANT+ logo on the device pairing screen.
How do I do this?
OK… so I have since been told that the ANT+ USB Dongle was to allow the smart trainer (Tacx Neo 2) to communicate with the Macbook Pro. The bizarre thing is - I can pull the dongle out and everything still works… another story I guess.
I have tried connecting a Garmin ANT+ HR Chest Strap - Not found. I have also tried putting my Fenix 3HR into the following:
Settings > Sensors > Wrist Heart Rate > Broadcast HR > Now… Not found!
Any other thoughts?
Have you tried other USB ports on the Mac? Are you sure the ANT+ dongle works? See if it works on another computer or see if it works for a friend.
The NEO can connect to your Mac using Bluetooth, that is why it works without the dongle.
