Hello,
I just bought a elite suito and I have a dongle ant+.
The suito is connected to zwift (green led) and is 3 meters away from the computer and the ant+ dongle.
When I want to go for a ride my avatar is not moving , watts are staying at 0 but RPM is working.
Can you help me?
Regards,
Damien
Bench
(Ben)
April 7, 2020, 12:04pm
2
Buy a USB extension cable and put the ANT+ dongle more near to your trainer.
Have you connected Power with ANT+ or ANT+ FE-C?
Use ANT+ FE-C for both power and controllable.
Can you show us a screenshot of your Pairing screen while you are pedaling.
Le mar. 7 avr. 2020 à 14:32, Paul via Zwift Forums gozwift@discoursemail.com a écrit :
Hello Ben, when im starting Zwift it tells me that power, cadence and controllable is connected.
How do you do to use Ant+ FE-C?
I bought an usb extension cable I will receive it on friday normally.
By the way I tried Bkool and it s working.
Thanks again for your help,
Damien
I would like to see the Zwift Pairing Screen (the screen where you connect your sensors) while you are pedaling.
Le mar. 7 avr. 2020 à 18:02, Damien Lemercier a écrit :
Change all connections to the FE-C option.
How do you change connections to FE-C option?
Thanks again
Use the orange button under each section, unpair and then search for the ANT+ FE-C option.
I tried this morning with the FE-C option and it’s working now!!
Thanks everyone for your help!!
