Move the location of the "Zwift" folder for Mac OS
There really should be the ability to move the ~/Documents/Zwift folder on MacOS, since the ~/Documents folder is now part of iCloud storage by default (I believe), so it unnecessarily takes up iCloud storage space which I really don’t want.
Should be able to set the location for log files and such (like a lot of applications).
I have the same problem. It gets worse if you have multiple Computers that are part of the same iCloud domain. I don’t even know which settings are synced. From my Laptop or the iMac.
Did somebody solve this?
This worked for me, moving the folder and making a symlink. It has to be done via the command line, I take zero responsibility for your system, it worked for me but your mileage may vary.
  1. command + space bar
  2. type in the word ‘terminal’ without the quotes and hit enter
  3. type: mv ~/Documents/Zwift ~/
  4. type: ln -s ~/Zwift ~/Documents/Zwift
Explanation of what’s happening … you’re moving the Zwift folder contained in Documents (step 3) into your home directory locally. You’re then making a pointer from Documents/Zwift to the actual Zwift directory in your home directory. This worked for me, runs fine after doing it. It might break in the future with an upgrade, but who knows. Zwift should really make it configurable to change this or move the hard coded path into the ~/Library directory where it belongs.
Zwift fails to open MacBook Air - it gets so far then pop up window shows error Zwift required access to the document folder, would you like to grant access now - another window asking to grant access now appears - despite granting access, then going into settings and granting access - it still comes back with error Zwift does not have access to the application folder! more than a little vexed with this now, i have followed another thread with similar issues but nothing! this error occured over 2 weeks ago, but as iI was about to start rest weeks I hoped the error may have disappeared - regrettably not any help appreciated before something is launched in frustration!!
@Mark_Williams_RAFCA
If you search “Zwift” in Mac Finder you’ll probably see multiple folders called Zwift, Zwift1, Zwift2, etc First thing you should do is move any custom workout and personal best files out of harm’s way, then delete everything Zwift-related on the hard drive before downloading the app and installing a fresh instance. Step by step instructions are here.
With macOS, when you update the OS, the app security settings get returned to a more restrictive default, and you might have to manually re-allow your apps permissions they might need. If the Zwift app can’t write to the Documents folder, it can’t launch. Repeating this over and over creates the Zwift1, Zwift2 etc duplicate folders. Hope this helps explain what’s happening!
@shooj good advice here but i’ve tried this 3x over and still no luck with getting access for Zwift: Zwift even has Full Disk Access now! See screenshots - any thoughts?
Hi @Adam_Towvim welcome to Zwift forums.
Instead of full disk access, please check the Files and Folder access, which is different. See this Apple Support article and let us know if that solves your situation?
thx for the reply!..an update since i posted to you (and sorry for not closing the loop here): I did give it Full Disk Access but still no dice: I fired up Terminal and made sure that I was in full Admin mode, then it all worked from there. I didn’t go Full Root Access, just Admin. I just googled, “how force macos launch application as administrator”
The fact that Zwift puts its files under ~/Documents instead of ~/Library (where apps are supposed to put things) is pretty terrible architecture to begin with, and it’s worse when you mix in sync apps. At this point it might be too late to fix that properly, but they could at least make it configurable…
In my case, the “Documents” folder is synced by OneDrive and I’m unable to disable that (work device, though they’re fine with reasonable personal use), so I ended up making a separate user account just for running Zwift.
The solution I came up with is just hiding the folder altogether.
You can run the command ‘chflags hidden’ + folder directory and that will hide it from your normal folder view. It doesn’t help with the icloud issue but helps with decluttering the folder.
