Mounting Zwift Ride bike on to Elite Suito-T trainer
Can anyone advise if they’ve had issues mounting their Zwift Ride on to an Elite Suito-T trainer? I attached the Zwift Cog no problem, but the width of the forks on the Zwift Ride at the rear is too wide to sit on the Suito-T. I’m using the adapters I had, and the Zwift Ride didn’t come with any alternative adapters. All the information online seems to relate to installation with the Kickr Core, not other brands!
Adapters are specific to the trainer. 142mm thru-axle adapters would have come with the Suito when it was new. If you can’t find them then you would need to buy a replacement set.
https://elitesrl.zendesk.com/hc/en-us/articles/360021012440-Adapters-required-based-on-the-bike-you-will-be-using-with-Avanti-Justo-Justo-2-Rivo-Direto-XR-Direto-XR-T-and-Suito-Suito-T
Thanks Paul: yeah that’s what I figured. I don’t remember there being additional ones to the ones I have in hand. It’s infuriating as it’s the only thing I can see stopping me getting the new frame mounted on to the Suito-T. I’ll check out the link you sent to see if I need to order a new one! Hopefully it won’t be too long if I have to send for one! :frowning:
