Anyone know a way of making the mini map larger on an iOS device? Using an iPad and it’s really hard to read
You should be able to tap it and get 3 different perspectives.
It won’t resize it, but it will change view a bit.
That option is not available on AppleTV.
Thanks Dan, rode this morning using the companion app instead which has a full screen map… problem solved I think ![]()
That’s what I do since I use AppleTV for Zwift.
I also have a Raspberry Pi that I use to pull up ZwiftGPS to give me the full map.
{when ZwiftGPS works, that is…}
