Milestonepod app
It is not possible to download the milestonepod application from the appstore (iOS) for my region. Why?
Because it is no longer supported by Zwift.
So throw it in the trash?
Is it still sold in the Zwift store?
Does not understand!!!
You can use the Zwift Run Pod with any Bluetooth App, including Zwift, Zwift just no longer supports the Milestone App.
Ok super.
How to change Runpod parameters and settings now?
In the application you could choose shoes and update the software.
Firmware updates are done using the Zwift App. On the Zwift App Paring Screen you will click on the wrench symbol and if there is an update available there will be a popup letting you know.
ok thank you, problem solved
