My Milestone foot pod used to work wit Zwift until about a week ago. The Milestone pod it self syncs fine (milestone app) Zwift finds the pod via bluetooth in the Zwift app but when I say “Run” it will not recognize that I am running (even if I go up to 10mph) so its not a speed issue. Anyone else have this issue?
Hi Ken,
Thanks for reaching out!
Have you made sure that you don’t have the Milestone app open at the same time as Zwift? Signals can be hijacked away from Zwift. If that doesn’t work, try removing and reinserting the battery.
Try that and let me know how it goes!
Same issue…when I try to calibrate pod disconnects but pod is still paired with zwift. Pod app is not open
Voila! Removing and reinstalling battery is the trick! Now if can just make the model go faster! :-)
