I don’t use Zwift often for running but when I have it’s with Milestone Pod. Everything worked pretty seamlessly in the past- but today Zwift wasn’t detecting any movement via Milestone Pod. Tried updating Zwift and Milestone firmware but it didn’t resolve the issues. Any suggestions would be appreciated.
Take out the battery and put it back in and if that doesn’t work try a new battery.
What Paul said. This happened to me, contacted Support, they said the same and it worked. Also, update the firmware on the pod.
I’ve found that to ‘run’ Zwift you need almost a full battery otherwise although the pod links to zwift once you start running nothing happens except your avatar starts doing stretching exercises. I seem to get about 6
or 7 30 mins run out of a battery before the power runs too low for zwift
Yeah, the MilestonePod’s battery level indicator is only for recording internally. When broadcasting Bluetooth to Zwift or a sports watch, it needs new batteries all the time.
I had the same problem on multiple different run attempts, 2 at the gym and 2 outside. I was “Connected,” but the avatar was not moving. I took the battery out for like a minute and put it back in… It FIXED IT!!!
