Memory Error on AppleTV 4k (2022)
Running Zwift on an AppleTV 4k (2022 - not the version which came out in October) with no issues. Tried a Video ride (Colorado Sunrise) with no issues on Sunday, but when I tried another one on Monday received a “insufficient memory “ error - says it needs 1.7GB to download the route but the device is “running low”. Device has 64GB with less than 10 used by installed apps (Zwift uses the most at about 7GB). Rebooted the device- Same results today. Any suggestions?
Are you force-closing the Zwift app after every use? You might also download one of the apps that checks your ATV memory usage to see where space is being taken up.
Zap it and try again. Unfortunately Apple TV gives you almost no insight into your storage, but this often helps.
The error is from aerials screensaver, each video takes 1GB of storage. The only way to clear that I found was to factory reset and immediately go into screensaver and turn off aerials (set to photos from icloud) then reinstall zwift. Make sure to photo any customized setting you have for the appletv so you can adjust back to original.
I got this message when the AppleTV had downloaded an update but hadn’t yet installed it. Installing the update fixed it.
This did the trick. Was a pain to reset, update and reload, but obviously not Zwift’s fault. After completing these sets I was able to enjoy one of the longer video rides this morning. Thanks!
Glad it worked, it would be nice if there was a way to delete the apple screensaver videos without an entire reset. Have a nice day
