Crashes once every time
Every time I click Zwift on Apple TV, it crashes once and have to click it again to start.
also I wish it would just start with some defaults instead of multiple screens and clicks and screens and clicks and screens and clicks and screens and clicks and screens and clicks before you find the program you always want to use over again. Takes several minutes to start each time. Isn’t there a faster way?
Which model is it? The HD 4th gen has only 2GB RAM and low memory has been a source of stability problems.
A1625 recent model w 64 Gig
Actually model is a few years old now that I search it, plenty of memory though. Thanks.
but looks to be 4th generation
I see that ram is only 2gb and 3rd gen latest has more.
I might try an upgrade at some point, maybe when new refresh which I hear could be 2026
Get a Mac Mini instead, way more power and will handle Zwift so much better. No Bluetooth limitations either.
Yep so with that device you are on one of the weakest systems that will run Zwift at all, which means if anything goes wrong, bad things happen to the game. If a bug pushes Zwift beyond the memory budget, you’re dead in the water until they release another update or emergency fix. It’s nice to have a bit of a buffer against that happening, since it has happened a few times that I can recall. As long as you are using it, I suggest force closing Zwift after every time you use it: Force Closing Zwift
A newer model would be more reliable. I agree with Mike that a Mac Mini is a much stronger device with fewer limitations, and even a used M1 Mac Mini from eBay would be a huge upgrade without a big expense.
Thanks guys. I hadn’t considered a Mac mini and will check into that!
You could also look at buying any of the 4K Apple TVs second-hand. My first-gen 4K ATV runs Zwift fine.
