macOS: why a Terminal window at startup?
Hi - since one of the recent Zwift updates on my MacBook Air (macOS Monterey 12.3), I’ve seen a new behavior whenever Zwift launches - a Terminal window opens up and runs a lengthy script (initial part included below). Why is this happening, and how do you make it stop? IMHO, an end user should never be exposed to a Terminal window - not only is it annoying, it opens the possibility of a user mucking up something in their system.
Thanks,
Barry
Last login: Wed Jun 15 13:46:49 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
ZimdandyMac:~ barry$ /Users/barry/Library/Application\ Support/Zwift/ZwiftApp ; exit;
Changing working directory to /Users/barry/Library/Application Support/ZwiftOpen assets/global.wad in file 0x1196fc98
 compressed size   = 4913363
 decompressed size = 15521440
Interleave mode: Loading / Decompressing WAD...  0%
 33%
 43%
 54%
 65%
 75%
 86%
 97%
100%
 Done!
Close file 0x1196fc98
Open assets/Worlds/worlds.wad in file 0x1196fc98
 compressed size   = 262648
 decompressed size = 385924
 Done!
Open assets/Environment/Ground/textures.wad in file 0x1196fc98
 compressed size   = 6427061
 decompressed size = 6999314
 25%
 33%
 41%
 49%
 58%
 66%
 74%
 82%
 90%
 98%
100%
 Done!
Open assets/UI/WhiteOrangeTheme/WhiteOrangeTheme.wad in file 0x1196fc98
 compressed size   = 1841855
 decompressed size = 11996754
 86%
100%
 Done!
Open assets/UI/minimap/minimap.wad in file 0x1196fc98
 compressed size   = 138865
 decompressed size = 1314514
 Done!
Open assets/UI/WhiteOrangeTheme/Scotty/Scotty.wad in file 0x1196fc98
 compressed size   = 246800
 decompressed size = 3069778
Hi @Barry_Smith1 welcome to Zwift forums
Shuji at Zwift HQ here. Just noticed your thread and looked into your server logs to see what might have triggered the terminal window. The day before you posted your question, it looks like the Zwift launcher app was updated to the latest version 1.1.1.
The installation of the launcher app would have triggered the terminal window. Now that Launcher 1.1.1 is installed - has the terminal window stopped appearing?
Hey @shooj, i have the same issue months later.
When i open Zwift, i always have to log in with password (no options to stay logged in) and then terminal starts pushing code through the syntax. Stays open the whole ride and when i close the app, its still there. Every day the same. Any ideas?
Have you already tried reinstalling Zwift?
i have the same issue now.
When i open Zwift, i always have to log in with password, and then terminal starts pushing code through the syntax. Stays open the whole ride and when i close the app, its still there. Every day the same…
That sounds like you are running the Zwift app directly instead of the launcher app. The launcher app is named “Zwift” (aka, /Applications/Zwift.app). The app itself is named “ZwiftApp” or “ZwiftAppSilicon” depending on your hardware and lives in ~/Library/Application Support/Zwift
Make sure you’re running the launcher.
thanks paul.
when i download from the internet for mac os, then i get only the the app „zwift“ and not „zwiftapp“.
i no not understand why, but after reinstalling it works now.
mark
Same issue here (August 2025). This started with the latest update. I have to log in every time I open Zwift and Terminal runs the whole time I’m riding (and stays open when I quit…)
Make sure you launch Zwift using the Laucher and not the zwift application directly, as Paul is explaining two posts above this one.
BòóX
