Zwift works fine on my old (2008) 17" MacBook Pro.
4GB Ram, 512 MB Graphics card
FTDI adaptor (which works ok with PC and Ergvideo stuff) , ANT+ for cadence from Powertap Pro, and Garmin ANT+ HR strap.
However, when I try to run the same setup on my newer 15" Retina Macbook Pro, the Computrainer cannot be found/seen in order to connect. The ANT+ devices are all ok.
The different I thought was that the newer machine was USB3.
I found a later version FTDI driver on their web site for OS X 10.9 and above. Installed it and on the first time in Swift the Computrainer was seen on Com0, however it didn’t connect. The computer hung with a BBOD.
Upon restarting there has been nothing on the computrainer side after many different attempts of swopping USB ports, starting up in different sequences, etc. The ANT + stuff are all still ok.
Any assistance is welcome.
I should note that I did not uninstall the older FTDI drivers before installing the later one (FTDIUSBSerialDriver_v2_3.dmg) because I do not know how to do so. Perhaps this is the problem?
