Lost connection issues
Hi my Wattbike Atom keeps losein connection when racein on Zwift, the only difference between that an any other ride on Zwift is that I use Discord app to talk, Discord is run through my phone and Zwift is run via a tablet so the Connections are separate so should not be a issue, is this a issues or fix that you have come across?
Hi @Craig_Scott_Army_Cyc
Welcome to the forum.
Lost connection can be caused by many different factors. From fans to Bluetooth headphones.
I would suggest eliminating some of the things that could interfere until you find the culprit.
I assume you use Bluetooth to connect to the trainer.
