Bugs(help)
Whats with all thw bugs? difficult enough being stuck on 100 percent trauner difficultly. No Bluetooth connection lost during race.
Is anyone sorting these ussues out?
Hi @stephen_sharp9124, connection loss is most times an issue with equipment or signal interference, probably not a bug with Zwift. You may want to try www.zwiftalizer.com to see if you are getting bluetooth signal issues.
Thanks Mike…using the same eq for last 18 month’s. No issues until last week.
The last update, unless you use Apple TV, was on Oct. 17th.
Did you try zwiftalizer?
