For the last couple weeks. I have randomly had drop outs. All my power numbers in the top left hand corner, drop to zero. My avatar stops. I have gone to connections a couple times, and it says that I’m still connected. Since getting direct connect, I have had zero issues, until now.
If I keep peddling, it comes back, after a few seconds. Usually long enough, that it’s really hard trying to get back onto the group. Or really screws up a sprint. Lol
Just curious if this is a me problem, or a more wide spread problem.
It has probably started since 1.79 update.
Not a general problem. What are you running the game on and how is everything paired?
I have windows 11 laptop. AMD processor
Companion app to bridge heartrate and controllers.
I have a kickr move, previously a kickr 5
I have had zero issues, ever since I got direct connect. At least 2 years, until now
If that system has a Ryzen processor and Radeon integrated graphics, then it may have been cursed in a recent update. You should check resource utilization when you are having problems. You could also upload game logs to zwiftalizer.com and see if the frame rate craters around the time you are getting disconnected.
Yep, you are probably right. It says AMD Ryzen
Thanks for the link @Paul_Southworth .
I have read through the thread a couple time.
So far my laptop has only froze for a few seconds, then I’m able to keep rolling.(It won’t utterly detroy my experience, just disappointing)
I’ve checked all my settings, and they should be fine. The only thing I have is OBS, but I haven’t used, since I stopped racing on the ladder. Hopefully Zwift can find the problem soon.
I really appreciate your help. Cheers
