Hi.
First time I post on this forum.
Today I finished stage 3, Long route on Quatch Quest in Watopia.
On the top of Alpe du Zwift I finally won the Lightweight meilenstein wheelset. Happy for that, BUT i cant find the wheelset anywhere?? Not in the garage either. Any suggestions for me😀
Thank you!
Refards Kai (Norway)
When you are on the tron bike you can’t select the Meilenstein wheelset. Select a different frame, then you should find your Meilensteins in your garage.
Hi. Thank you for answering. I have tried to change bike, but anyway the wheelset isnt in “wheelbox” in my garage. So i cant choose It.
The tv screen, when i finishen at the top, and the companionapp showed/shows that I got It, but Not the garage.
what frame have you got selected in your garage?
I tried with Specialized Tarmac😊
how many wheelsets are showing under wheels?
I’ve got four wheelset.
try closing the program and restarting, it may take a bit to get in there.
Hi. Ok, I will try that tomorrow. I let you know then, if It works. Thanks, so far
