Just upgraded the the original Zwift cog to the version 2 Cog with compatible freehub for my trainer; an Elite Suito.
I followed the instructions that came with the cog and consulted the installation video on the Zwift website but I’ve found the cog has some lateral play once installed. I say the cog, what I actually suspect is the play is coming from freehub and the trainer, almost as if a spacer is missing.
I looked at the Elite freehub I removed from the trainer and it had a very small rubber washer which the Cog’s freehub doesn’t.
1. Is there supposed to be 2-3 cm of lateral play on the freehub? Someone on another forum suggested there should be to allow for chain alignment.
2. Is there some sort of washer or spacer that should have been included that is missing? I doubt this is the case as there is no mention of one in the manual or online
