I have had a Kickr Core for a few days now and am very satisfied. However, I have a strange behavior when riding uphill.
At a low cadence of e.g. 60rpm and approx. 170-200 watts on a 10% incline, I can no longer pedal completely smoothly when I’m in the easiest gear (36 front, 34 rear). Trainer difficulty is at 100%. It feels like falling into a hole at the bottom of the crank rotation and having to pedal beyond it.
The standard advice is to use the Wahoo Fitness app to check for firmware updates, perform a calibration, do a ride using the Wahoo app (or SYSTM), and see if you can replicate the problem there. If so you can talk to Wahoo support without the risk of any finger pointing between Zwift and Wahoo.
I have had similar issues with an H3 but with a little lower cadence and higher watts. Note I am at 100 kilos. I think this is the edge of performance of the flywheel/trainer. The trainers tend to not like low rpms. My resolution is to lower the Trainer difficulty to get the unit to spin faster. That smoothed it for me.
I haven’t found a solution yet. The strange thing is that when using ERG mode, at very low cadence and high power, the problem doesn’t occur. The problem only happens in free mode.
