Kickr Bike V2 – Tilt stops working after a few minutes on Zwift 1.97
Hi everyone,
since updating to Zwift 1.97 I’m experiencing a strange issue with my Kickr Bike V2. At the beginning of a ride the tilt function works normally (bike moves up and down with gradients), but after a short time it simply stops responding. Resistance continues to work correctly, only the incline/decline movement is affected.
Here is my setup:
  • Kickr Bike V2, latest firmware
  • Connected to Zwift via Direct Connect (RJ45)
  • Garmin Edge 1050 sometimes connected in parallel via Bluetooth, but I tested without Garmin and the problem is exactly the same.
  • Trainer Difficulty set to 100%
  • Not in ERG mode, tested in SIM mode and different worlds (Watopia Epic KOM, Innsbruck, etc.)
  • Bike is in unlocked mode
I also tried:
  • Power-cycling the Kickr Bike
  • Re-pairing the trainer in Zwift
  • Testing with/without other devices connected
Nothing changes: tilt works for a minute or two, then stays flat for the rest of the ride.
Is anyone else on Zwift 1.97 seeing the same behavior? Could this be a new bug?
First report I’ve heard of it, I have a V1 but ride with a lot of folks on V2s and there’s been no mention of it from them.
I would ask Wahoo support to help you prove that the bike is not faulty
Bike is not, I tried with v1.96 on my laptop and it works.
Additional test performed today, when the tilt is no longer working, unpairing and repairing all the connections makes it work again.
Maybe a stupid question, can you or have you tried connecting via BLE?
(or ANT+ just know ANT+ creates a significant delay with tilt feature)
Almost wondering if for some reason it’s almost “going to sleep” on that side of things through the dircon; doesn’t make sense but, I haven’t a clue how dircon works (or any mode for that matter).
Also just to confirm, it STAYS unlocked correct? Does the V2 have the same light that shows tilt is locked/unlocked? I know if I walk away from my V1 for two minutes or so like during a coffee break, when I return the gear display turns off and it goes back to tilt lock mode.
Only valid questions, no problem :oncoming_fist:.
I’m in direct connection, RJ45, and yes there is a light like v1 to make sure you are in unlock mode
Dicton is nothing else as WIFI for ZWIFT.
Update of the day:
Dircon stop working after a couple of minutes
A switch to Ant+ works but I don’t have anymore the ZWIFT control buttons
Pair through ZC works as well and I have everything like Dircon and no problem during a 2h ride
So there is an issue with Dircon, could it be the new “preferred” connection setting trying to connect something else?
I would suggest working through this with Zwift support, who will then be able to see whether there’s a wider problem here. Start a support ticket from the website, or email support@zwift.com
Email sent
Update after contacting Zwift Support:
Zwift Support has confirmed that this issue (Kickr Bike V2 physical controls – shifters + Tilt Lock/Unlock – becoming unresponsive after a few minutes on firmware 1.97, while power/resistance still work) is a known firmware-related bug reported by multiple users.
  • The problem happens mainly with direct Bluetooth connection to Zwift.
  • Using ANT+ or Companion relay can reduce the frequency, but does not fully solve it.
  • Unfortunately, there is no rollback option to firmware 1.96.
  • Wahoo is expected to deliver a fix via a future firmware update, but no ETA has been provided yet.
:backhand_index_pointing_right: If you are also experiencing this problem, please report it here or directly to Wahoo Support so they understand how widespread it is and prioritize a fix.
For now, the only workaround is to avoid direct BLE and restart the trainer when the controls freeze.
V2 here, I think I have the same issue too. Did wonder why I couldn’t feel much tilt.
So we gotta wait for Wahoo to release a firmware update then?
On Wahoo firmware version: 2.2.22
Log a Wahoo ticket to increase the priority :oncoming_fist:
Just confirming I’ve been having the same issue.
Did you log a Wahoo ticket? I fear the only way to fix it is by getting a firmware update from them.
The last 2 activities I have done after the latest zwift update the wahoo kickr bike handlebar controls were locked mid session, I had to turn the wahoo kickr bike off and on to resume the activity. I’m the only one
I hear you, and hope Wahoo too. See my message here: Kickr Bike V2 – Tilt stops working after a few minutes on Zwift 1.97 - #15 by _Dean_Dirty_Reps
Any news?
Update of the situation —–
I’ve received and installed the new handlebar assembly as instructed. Unfortunately, the issue persists exactly as before.
After about 30 minutes of use, the shifters froze, the gear display stopped updating, and the Wahoo app showed the “Derailleur Error – it seems the derailleurs are disconnected” message. Resistance control continued to work normally.
This confirms that the failure is not related to the shifters or handlebar assembly, but rather to the control board inside the front display module (the PCB permanently attached to the frame). The symptoms clearly indicate a communication crash between the Handlebar Control Board and the Main Control Board.
