@Antoine_GOUGEON also having this issue on my kickr bike v2 Wi-Fi dircon. Im also having the issue that the resistance doesn’t change aswell as the tilt - its a bit like being put in ERG mode - the only way i can resolve it is to turn everything off and back on again - seems to be ok for a completely random time period then lose resistance changes and tilt. I shall put in a ticket to wahoo.
The support helped me to fix it, new shifters
I thought you said in previous post that the new handlebar assembly and shifters did not rectify the problem?
I also had a motherboard issue affecting gears, but resistance and tilt were ok after new shifters. The best thing to do is open a Wahoo ticket and work with support. Each case is different, but most are related to shifters and electronics on the board (where you see the gear numbers).
